Beküldte 444tibi -
Teljesen újrahúztam a rendszeremet (Manjaro KDE), új telepítés, mnden frissítés megvolt, naprakész.
A 4kWideodownloader simán települt, függőségével együtt, de az indításnál egy pillanatra látható a panelen az ikonja majd kilép.
Terminálban elindul és az alábbi üzenetet adja:
[tibi@tibi-manjaro ~]$ 4kvideodownloader 07:05:05 +0200 (0x00007fcaf5a90a80) [info] Launched with arguments: /usr/lib/4kvideodownloader/4kvideodownloader-bin 07:05:05 +0200 (0x00007fcaf5a90a80) [info] [app_Gui] [Translator] Using locale hu_HU 07:05:05 +0200 (0x00007fcaf5a90a80) [info] [SoftwareUpdate] [Manager] appId=4kvideodownloader, appName=4K Video Downloader, appVersion=4.9.0.3032, appCast=https://www.4kdownload.com/static/main/app/appcast/videodownloader.xml kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by kde-open5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5KIOWidgets.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5KIOCore.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5I18n.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5CoreAddons.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5JobWidgets.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5Service.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5Completion.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5IconThemes.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5ConfigWidgets.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5WindowSystem.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5WidgetsAddons.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5ConfigGui.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5ConfigCore.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5Crash.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5DBusAddons.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5AuthCore.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libQt5X11Extras.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libQt5Svg.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5Archive.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5ItemViews.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5Codecs.so.5) kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libKF5GuiAddons.so.5) ADVERTISEMENT: HU:hu 07:05:05 +0200 (0x00007fcaf5a90a80) [info] Agreement not found 07:05:15 +0200 (0x00007fcaf5a90a80) [info] [SoftwareUpdate] [Manager] checking 07:05:17 +0200 (0x00007fcaf5a90a80) [info] [SoftwareUpdate] [Manager] parsing 07:05:17 +0200 (0x00007fcaf5a90a80) [info] [SoftwareUpdate] [Manager] no update available
Próbáltam ráresni erre a libQt5-re de nem lettem okosabb.
Hogyan kell ezt "beszereznem"?
A Qt5 5.13-as verziónak kell
A Qt5 5.13-as verziónak kell telepítve lenni. A "qt5-base" a csomagnév, vélhetöen ezt elég telepíteni (legalább a fenti verziószàmban, nem kötelezö pontosan azt)
Az Arch extra repoban "qt5-
Az Arch extra repoban "qt5- " meg fogod találni, van jónéhény eleme.Jelenleg 5.13.0-1 futkároz...
Beküldte 444tibi -
25 darab qt-5 kezdetű valami van gyárolag telepítve, köztük legelső a qt5-base 5.13.0-7.1 nevű.
A 4kvideodownloader valami kde-open5: /usr/lib/4kvideodownloader/libQt5Core.so.5 nevűt hiányol, a .so az nem olyan mint valami -exe, vagy inkább mint egy dll? Ezt viszont nem tudom, hogyan tudnám beszerezni.
A ClipGrab 3.8.4-es Appimage-t használom helyette.
A Debian alapú rendszeren, a dpkg-val, így nézed meg, melyik csomag tartalmazza:
A találatok:
A libqt5core5a csomag tartalmazza.
A Manjaro nem használ dpkg-t. De van hasonló funkciójú alkalmazás.
Kézikönyv:
Részlet:
Először is, meg kell találni a 4K Video Downloader indítóját.
Amire, ha kettőt kattintasz elindul az alkalmazás.
Máshogyan ez a „Futtatás” (./): ./pkg.bin
Debian alapú rendszeren a which parancs segít (példa):
Megnézem, milyen könyvtárakból dolgozik (példa):
Ha tudnánk, melyik csomag verzió kell az alkalmazásnak, könnyebb lenne.
Részletes hibaüzenetekből tán kiderül (te látod, mi nem látjuk, csak egy részletet írtál). Illetve a netről, hasonló problémákból.
Tegnap és is hasonló témában keresgéltem:
https://linuxmint.hu/blog/2018/06/a-viber-voip-alkalmazas-telepitese
Én a Youtube DL-t használom. És a Video DownloadHelper böngésző kiegészítőt.
Ami kell, olyasmi igen, mint a DLL.
What is a DLL? A DLL is a library that contains code and data that can be used by more than one program at the same time.
http://man7.org/linux/man-pages/man1/ldd.1.html(külső hivatkozás)
Osztott programkönyvtárak ...
Magyarázat - a teljes elérési utakkal:
környezeti változó (LD)=az alkalmazás „lib” könyvtára (ha van külön) [szóköz] az alkalmás binárisa (kettő kattintásos)
Rá is lehet keresni (a problémára): ldd linux vagy libQt5Core.so.5 linux (kifejezések) vagy alkalmazásnév libQt5Core.so.5 ...
https://forum.qt.io/topic/76300/libqt5core-so-5-version-qt_5-not-found(külső hivatkozás)
https://bbs.archlinux32.org/viewtopic.php?id=1295(külső hivatkozás)
... (példák, de nem igazán megoldások).
Beküldte 444tibi -
A letöltési ablakba megjeleníti az összes letölthető felbontást, video, audio minőséget, formátumot és kiválasztom a nekem kellőt 1 kattintással és már jön is lefelé.
Egyébként mint írtam, terminálból indítva simán indul, épp most szedek le párhuzamosan vagy 10 klipet.
Csak rendesen indítva hiányol valamit, terminálból indítva meg megy, én ezt nem értem.
A desktop fájlban, az Exec sorban mi szerepel?
A find és grep parancsot remélem, használja az Arch Linux.
A gea kifejezésre szűkítéssel (grep) megtudjuk, a Debian-alapú rendszernél itt vannak (többek között) a desktop fájlok:
Telepítve van a kde-open5 alkalmazás? Verziószáma 5.13? Ezt hiányolja (required) a 4kvideodownloader.
Könyvtár tartalmának listázása:
De lehet a fájlkezelőt is használni, viszont az abban megjelenített név, nem a fájl neve, hanem az alkalmazás neve lesz. Ami kicsit megtévesztő ..., viszont meg lehet nyitni egy szövegszerkesztővel, amely lehet például a Geany is:
Egér jobb gombos menü > Megnyitás a * szövegszerkesztővel...
[*] a telepített, alapértelmezett szövegszerkesztő a rendszereden.
Beküldte 444tibi -
GenericName=4K Video Downloader
Comment=Download online video
Exec=4kvideodownloader
Terminal=false
Type=Application
Categories=Network;Qt;
Nálam Kate az alapértelmezett szövegszerkesztő.
kde-open5 nincs, de sehol, semelyik tárolóba sincsen, legalábbis a szoftvertelepítő (Octopi) nem talál.
Használom terminálból. Épp most szedi le a Shaun the sheep 20 epizódját, egy ismerősnek kell a gyereknek.
Telepítettem a youtube-dl-t, meg a dlg-t , jelenleg ismerkedési fázisban vagyunk. :-) Ha beválik, a 4kvideodownloader nem is kell.
https://forum.qt.io/topic/65098/kde-open5-relocation-error/3(külső hivatkozás)
https://userbase.kde.org/Tutorials/Open_a_console(külső hivatkozás)
Azt nézem, olyasmi, mint az xdg-open.
Talán a kde-cli-tools csomag része.
https://www.reddit.com/r/kde/comments/ch1imr/deleted_my_kdeopen5_file_fr...(külső hivatkozás)
Bug lehet, jelenteni kéne ... .
A HTop indítóm ezt tartalmazza:
Ezen a nyomon elindulva, próbáld így szerkesztve tesztelni a dolgot
vagy
Utóbbi parancsot a használat előtt próbáld ki terminálban:
libQt5Core.so.5
Megtaláltuk? Nem.
https://linux.die.net/man/8/yum(külső hivatkozás)
A dolgok nem kívül kezdődnek, hanem belül, és nem alul, hanem felül, és nem a láthatóban, hanem a láthatatlanban.
libQt5Core.so.5
[andrea@andrea-pc ~]$ pkgfile -l qt5-base | grep libQt5Core.so.5
extra/qt5-base /usr/lib/libQt5Core.so.5
extra/qt5-base /usr/lib/libQt5Core.so.5.13
extra/qt5-base /usr/lib/libQt5Core.so.5.13.0
libQt5Core.so.5
Beküldte 444tibi -
""Oszt (pedig elmondtam többször is :-)) mondom ismét, keress rá a „lehetetlenre”:"
Beismerem, ezzel késtem, azóta kutakodtam és amit hiányol, az ott van, abban a mappába ahol hiányolja.
Minden qt5 telepítve van nálam.
Vagyis ez a baja:
És ez van a könyvtárába:
Akkor miért hiányolja..?
É ha Dolphinba látom, listázásra miért nem látom?
[tibi-manjaro 4kvideodownloader]# ls
4kvideodownloader-bin libQt5Gui.so.5 libQt5Xml.so.5
4kvideodownloader.sh libQt5Network.so.5 platforms
audio libQt5Qml.so.5 translation
libQt5Concurrent.so.5 libQt5Widgets.so.5 xcbglintegrations
libQt5Core.so.5 libQt5XcbQpa.so.5
libQt5DBus.so.5 libQt5XmlPatterns.so.5
libQt5Core.so.5
Beküldte 444tibi -
Terminálba a válasz:
[tibi@tibi-manjaro ~]$ pkgfile -l qt5-base | grep libQt5Core.so.5
bash: pkgfile: parancs nem található
libQt5Core.so.5
libQt5Core.so.5
Beküldte 444tibi -
Ennek ellenére nem megy a program.
Nem telepítettem semmit, vagyis sok mindent de a 4kvideodownloader telepítése után kijelentkeztem meg be és próbáltam indítani. De már akkor nem indult.
Nem gond mert terminálból indítva hibátlan, már rááll a kezem hogy így indítom.
A probléma ugyan nem megoldva hanem megkerülve, de ez a végeredmény szempontjából közömbös.
A youtube-dl is jó, próbálgatom, természetesen a gui alól. Hogyan lehet rávenni komplett lejátszási lista letöltésére?
JDownloader
Tegnap telepítettem a JDownloadert erre a rendszerre is (Debian 10), de a telepítö sripttel nem ment. Így letöltöttem PPA-ról az Ubuntu 16.04 kiadásra való jdownloader-installer alkalmazást, és telepítettem. Az alkalmazás az elsö indításkor felajánlotta, hogy felfrissíti magát a JDownloader 2 Beta verzióra, amit elfogadtam. Végül el kellett távolítanom (purge) a jdownloader-installert, ezáltal elindult az újabb verzió.
Mindezt azért írom, mert az alkalmazás Arch Linuxra, saját Git csomagként érhetö el. Letöltöttem azt, de mivel lett megoldás, csak a kíváncsíság hajt, miként készíthetek pkg fájból deb telepítöt.
A JDownloader nem szimpatikus neked?
libQt5Core.so.5
pacman -Syu
https://wiki.archlinux.org/index.php/System_maintenance#Partial_upgrades...(külső hivatkozás)
https://bbs.archlinux.org/viewtopic.php?id=227055(külső hivatkozás)
Ugyanezt a verziót
https://aur.archlinux.org/packages/4kvideodownloader/(külső hivatkozás)
telepítettem (Debian), ennyit mond:
Ez egy bug. A Custom Qt nem ér össze a rendszer-telepítettel:
Looks like your Custom installed Qt 5 is interfering with your OpenSUSE installed Qt 5.
MI van a fájlban?
https://forum.teamspeak.com/threads/131020-KDE-Can-not-open-links(külső hivatkozás)
pacman -Syu
pacman -Syu
pacman -Syu
pacman -Syu
pacman -Syu
A desktop fájban a "Terminal=true" beállítás jó lehet. Más nem kell. Ekkor egy terminál is megnyílik a háttérben. Így biztosan elindul menüböl is az alkalmazás. Ki kéne próbálni, hogy ezzel a módszerrel nyitja-e a videót ... az URL-t csak beillesztve.
A kde-open5 és az alkalmazás különbözö Qt verziót igényel. A fájltársításnál lehet gond, ott van a kde-open5.
pacman -Syu
pacman -Syu
Beküldte 444tibi -
Sajnos nem jó.
Figyelmeztetés: Nem sikerült elindítani: „/usr/bin/4kvideodownloader” (argummok: „/usr/bin/4kvideodownloader”).
Figyelmeztetés: execve: Érvénytelen végrehajtható fájlformátum
pacman -Syu , eredménye, minden naprakész, sőt talált egy valamit ami frissebb mint a tárolókban,
: A csomagadatbázisok szinkronizálása...
a(z) core naprakész
extra 1886,8 KiB 2,08M/s 00:01 [##################] 100%
a(z) community naprakész
a(z) multilib naprakész
:: Teljes rendszerfrissítés indítása...
figyelmeztetés: python-pip: a helyi (19.2.3-1.0) újabb, mint a(z) extra (19.
0.3-1)
nincs teendő
Az Octopihoz nem tudom hozzáadni az AUR tárolókat, mert a trizen beállításánál ezt írja:
Icon path information is incomplete.
Ezért az aur cuccokat a Pamac-ból frissítem, az simán lekezeli az aur-t. De az is azt írja hogy a rendszer naprakész, be van állítva az aur frissítések is.
Kget is elkezdte
Beküldte 444tibi -
Nem nyitok újat, bár lehet kéne,
a Kget letöltésvezérlő is ugyanezt kezdte mától. Tegnap még használtam, ma indítom, pillanatra megjelenik az ikonja a panelen majd eltűnik.
Parancssorba beírva kget , semmi.
Ami tegnap óta történt, az nem sok, felpakoltam a Free File Sync nevű programot. Létezik hogy az kevert be,, nem hinném.
Valami hibakeresésre kaphatnék útmutatást?
Kget is elkezdte
Valami egyedi módszerrel? Ugye, nekünk nem biztos, hogy van telepített Manjaro-nk, azért kérdezem. :-)
A Free File Sync MediaFire-es letöltése sem meglepő :-),
https://freefilesync.org/download.php(külső hivatkozás)
ha az ember már találkozottmár a JDownloadernél a Mega-s letöltéssel.
De ahogy nézem (futtattam), körülbelül ugyanazt tudja, mint a gFTP. ;-)
https://www.gftp.org/(külső hivatkozás)
Szinte minden Linux terjesztésen elérhető a tükrökről, nem kell letölteni.
Ha erre van szükséged, azt mondom ... használd egészséggel. Nagyon jó.
... ja, Gnome-os, nem KDE-s.
https://www.youtube.com/watch?v=AUxOF7eLA_0(külső hivatkozás)
pacman -Syu
@#30 Manjaro alatt nem ugyanitt van. Hanem itt:
Próbálkoztam ezzel:
Keresés
Az eredeti átnevezése (biztonsági mentés)
A rendszer által adott verzió bemásolása a nemrég átnevezett helyére
A végeredmény:
... az alkalmazás nem indul el. Más a két Qt verzió.
Helyreállítás (röviden):
Így visszatér a hiba, ami korábban is volt:
... illetve néha nem tér vissza. De menüből nem indul.
Mindez egyértelműen az AUR-ból származó csomagok hibája lehet. De jelzik is, hogy nem stabil ... .
Neked sem kéne használni az AUR-t.
Használt megosztott könyvtárak:
A hibáról (rövidítve a kimenetet)
A libQtCore5.so.5 tulajdonságai
A lényeg
Régebbi Qt verziót használ az alkalmazás ... (mint 5.13)
Az is érdekes, ha a Konsole-ban új lapot nyitok, nem jelenik meg. Illetve ... ez amolyan Gnome Shellesen van megoldva, nekem elég zavaróan. Mmm nem, az ablak aljára került ... elképesztő. :-)
Kget is elkezdte
Beküldte 444tibi -
Onnan sem indul, a /usr/share/applications/org.kde.kget.desktop fájl.
Az ott lévő indítófájltartalma:
# KDE Config File
[Desktop Entry]
Type=Application
Exec=kget -qwindowtitle %c %U
Icon=kget
Terminal=false
MimeType=application/metalink+xml;application/x-bittorrent;
Name=KGet
Name[ar]=KGet
Name[be]=KGet
Name[bg]=KGet
Name[bn]=কে-গেট
GenericName[uz]=Yozib olish boshqaruvchisi
GenericName[uz@cyrillic]=Ёзиб олиш бошқарувчиси
INNEN kivágtam pár 10 sort mert a nyelveket sorolja fel,
ez jön a végén:
Categories=Qt;KDE;Network;FileTransfer;
X-DBUS-ServiceType=Unique
X-DocPath=kget/index.html
X-DBUS-ServiceName=org.kde.kget
De mint írtam itt sem indítható, valamint a 4kvideodownoladerrel elletétben, ami terminálból indítható és tökéletesen működik, a kget terminálból indítva semmit nem csinál.
Letöröltem a Free file Sync programot amit tegnap telepítettem, semmi változás.
aur-ból tettem fel egyébkét a rendszer csomagkezelőjével, nem máshonnan töltöttem le és úgy telepítettem.
Kget is elkezdte
Kget is elkezdte
Elméletileg így a rendszer Qt program könyvtáraival fog indulni, de a gyakorlat mutatja meg, mi lesz.
A kimenetet másold ide.
Ez alapján mondom:
A gond az a fenti parancssorral, hogy lentebb, mélyebben, de ugyanitt van az alkalmazás programkönyvtára is.
Na jó, gondoljuk azt, átvágjuk valahogy. Próbáld ezt is,
és a kimenet ugyanúgy kell.
Lehetne egy statikus Qt könyvtárat telepíteni, azaz létrehozni. És arra hivatkoznánk.
ldd | 4kvideodownloader.desktop
Terminál (parancssor):
Indító
A desktop fájl helye
és neve.
Megnyitás a Kate szövegszerkesztővel ...
Új, azaz szerkesztett tartalma:
Az alkalmazás menüből is indul.
Viszont jelenleg terminálból nem indul ...
-- illetve, így igen (azzal a parancssorral, amit betettem a desktop fájl Exec sorába),
..., de csak az előző parancs futtatása után így is (viszont hibajelzés nélkül).
Terminálban így is indul:
A desktop fájlban két megoldás lehetséges:
Ez esetekben indul el a menüből.
Kget is elkezdte | csak azt hiszed, hogy bezártad
Elsőre elindul, megjelenik a grafikus felület.
Megkérdezi, akarom-e, hogy a Konqueror alapértelmezett letöltő alkalmazása legyen. Akarom.
Bezárom. (*)
Innentől kezdve egyik parancssorral sem
indul el, és menüből sem.
Ez mondja az értesítés:
Átvitel (Failed)
/home/kimman/.local/share/kget/transfers.kgt
Jó ...
Vajon telepítve van-e a Konqueror? Nincs.
Telepítem az extra tükörről.
Még valami észrevettem. Megosztom.
A Panelen, az óra mellett balra van egy nyilacska. Ha arra rányomok, akkor ...
[*] Szóval ott, a talán sokatmondó „Status and Notifications” appban bújt el(külső hivatkozás) az egyszer már megnyitott, de (általad) sosem bezárt KGet. Ha egyszer elindítottad, ... akkor az ablak meg van nyitva, amikor bezárod, csak le van téve oda. Ha teljesen bezárod, úgy pl. a kget parancs is indítja.
Más asztali környezetek a Panelre valamilyen módon letett alkalmazások ablakát az újból indításkor egyszerűen megnyitják (például a Cinnamon, az Xfce, a MATE).
Beküldte 444tibi -
Valamint, a
Exec=LD_LIBRARY_PATH=/usr/lib/4kvideodownloader/ megoldással indul a 4k is hibátlanul.
Köszönöm.
