[Megoldva] Elromlik a Wi-Fi
Fél--egy óra használat után elromlik a Wi-Fi, ezért újra kell indítani a laptopot. HP márkájú a laptop.
A gép HP, de milyen WiFi van benne?
#1 System:
  Host: porc Kernel: 6.8.0-51-generic arch: x86_64 bits: 64
  Desktop: Cinnamon v: 6.2.9 Distro: Linux Mint 22 Wilma
Machine:
  Type: Laptop System: HP product: HP Laptop 17-cp2xxx v: Type1ProductConfigId
    serial: <superuser required>
  Mobo: HP model: 8A81 v: 41.23 serial: <superuser required> UEFI: Insyde
    v: F.16 date: 05/16/2024
Battery:
  ID-1: BAT0 charge: 40.9 Wh (100.0%) condition: 40.9/40.9 Wh (100.0%)
CPU:
  Info: quad core model: AMD Ryzen 3 7320U with Radeon Graphics bits: 64
    type: MT MCP cache: L2: 2 MiB
  Speed (MHz): avg: 616 min/max: 400/4150 cores: 1: 2129 2: 400 3: 400
    4: 400 5: 400 6: 400 7: 400 8: 400
Graphics:
  Device-1: AMD Mendocino driver: amdgpu v: kernel
  Device-2: Chicony HP True Vision HD Camera driver: uvcvideo type: USB
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
    loaded: amdgpu unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
    resolution: 1: 2560x1440~75Hz 2: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: radeonsi,swrast platforms: x11,surfaceless,device
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-0ubuntu0.3
    renderer: AMD Radeon Graphics (radeonsi raphael_mendocino LLVM 17.0.6 DRM
    3.57 6.8.0-51-generic)
Audio:
  Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp6x
  Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
  API: ALSA v: k6.8.0-51-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active
Network:
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    driver: rtw_8821ce
  IF: wlo1 state: up mac: 1c:ce:51:69:90:19
Bluetooth:
  Device-1: Realtek Bluetooth Radio driver: btusb type: USB
  Report: hciconfig ID: hci0 state: up address: 1C:CE:51:69:90:18 bt-v: 4.2
Drives:
  Local Storage: total: 476.94 GiB used: 45.14 GiB (9.5%)
  ID-1: /dev/nvme0n1 vendor: Phison model: PSEJN512GA87EC0 size: 476.94 GiB
Partition:
  ID-1: / size: 124.93 GiB used: 45.06 GiB (36.1%) fs: ext4
    dev: /dev/nvme0n1p5
  ID-2: /boot/efi size: 256 MiB used: 84.7 MiB (33.1%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  Alert: No swap data was found.
Sensors:
  System Temperatures: cpu: 35.0 C mobo: N/A gpu: amdgpu temp: 32.0 C
  Fan Speeds (rpm): N/A
Info:
  Memory: total: 8 GiB note: est. available: 7 GiB used: 2.27 GiB (32.4%)
  Processes: 316 Uptime: 3m Shell: Bash inxi: 3.3.34
Elromlik a Wi-Fi
#2 Network:
    vendor: Hewlett-Packard driver: rtw_8821ce v: N/A pcie: speed: 2.5 GT/s
    lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
csuhas32 képe
#3 https://forums.linuxmint.com/viewtopic.php?t=408218
Ez nem oly régi téma, szerintem itt is ilyen adapterrel küzdöttek, sikerrel.
Elromlik a Wi-Fi
1; Ellenoriznem hogy a BIOS-ban tiltva van-e a secure boot. (Legyen tiltva!)
2; A biztonsag kedveert csinalnek egy friss Timeshift visszaallitasi pontot.
Ezen az oldalon: https://easylinuxtipsproject.blogspot.com/p/realtek.html#ID6
A "Driver for the Realtek RTL8821CE chipset"-hez tartozo ajanlast hajtanam vegre.
(Ha kell, leforditanam az oldalt - a jobb megertes vegett.)
Elromlik a Wi-Fi
#6 E: Unable to locate package rtl8821ce-dkms
